Internal Storage filling up to full capacity
    Hi guys I have a couple of m8's which over the past month both have had freezing issues after further investigation I have noticed that the sd partion where the data folder is stored has reached maximum capacity causing any kind of streaming to stop. The folder causing the issue is the temp directory in the userdata folder.
    Any idea what could be causing this. I have the following these settings in my advancedsetting.xml file
    <!-- zerocache -->
    <advancedsettings>
    <network>
    <buffermode>0</buffermode>
    <cachemembuffersize>0</cachemembuffersize>
    <readbufferfactor>4.0</readbufferfactor>
    </network>
    </advancedsettings>
    My understanding is that this buffering mode gets automatically deleted...is this the case
    Thanks in advance.
    <!-- zerocache -->
    <advancedsettings>
    <network>
    </network>
    </advancedsettings>
    Thanks in advance.
    I think this belongs in the xbmc section of freak tab nothing to do with firmware
    Bugs are Sons of Glitches!
    JustMe
