Any ideas?
Telos is freezing
Try to use
(or the stock rom http://www.tronsmart.com/forum/trons...80-v2-0rc3#534)
at a SD card
and look what will happen (before you reflash it)...RK3288 Devices
- Overview BOX (LINK !)
Originally posted by bangsergio View PostHi no spam, it is already with stock rom didnt make any changes.
Finless rom does works with Telos?
And you can try different fw versions (to rule out it's a fw problem also maybe bad flashing by the factory)...RK3288 Devices
Telos is freezing
Originally posted by no_spam_for_me View PostI talk about "Boot from SD" because this way we can rule out problems at internal eMMC/NAND...
Danke schon
Greetings from NRW
Hi
Boot from sd using Finless Rom 1.1 beta 2:
got 1 freeze using MX player, after hard reset (power cord) 2 hours no freeze.
Using stock rom telos freezes after ca. 30 minutes with MX player need to hard reset using power cord.
Edit:
Still using stock rom + app no frills cpu set governor to interactive default settings, running stability test app no CPU freezes till now.Last edited by bangsergio; 12 January 2015, 15:47.
Edit:
Still using stock rom + app no frills cpu set governor to interactive default settings, running stability test app no CPU freezes till now.so i did.
Nothing changed because i still experiencing freezes sometimes while is booting, i've tried to reset the device using "fn" but nothing happens so i've reset the device under android and twr recovery still the same.
Freezing happens with stock, Bob's and Dovless rom, using setcpu to set governor to interactive seems to help a bit but as soon i go per example to google play store and update 3 or more apps at the same time i get a freeze and i have to pull the cord.
Does someone has more ideas or do i have to sent back my device?
PS: hope the guys from Geek are following this also.
Greetings from Germany
Because you tried different fw's it's definitely a HW issue...
I don't know, if the PSU is the problem or the device (maybe except eMMC/NAND because you also tried boot from SD with the same result)...
Anyway, many others have not such problems at the different fw's
(sometimes I also hat a freeze, BUT not so often as you at your device...)RK3288 Devices
Originally posted by no_spam_for_me View PostBecause you tried different fw's it's definitely a HW issue...
Im installing Kodi and copy paste settings to Kodi still stable, open Kodi to set up a few things wait one freeze more.
Pullout cord go to Kodi seems to be stable again.
I really dont understand the all morning getting freezes and for over one hour i get only one.
Im wonder if i can use a apk to stress cpu/ gpu / ram???
PS: I really apreciate your Help.
PPS: Ok i got one more freeze and now it freezes at boot not possible to go to desktop.
I could try another PSU if i know wich one to buy, can you help here?
Geekbuying people I hope you are following this.Last edited by bangsergio; 13 January 2015, 14:57.
The stock one is 12V/2A using 5,5 x 2,1mm plug...
Here you find e.g. 3A (also 4 and 5 A)
http://www.****.de/itm/111356647116?...%3AMEBIDX%3AIT
Here is another one, but I can't find any information about the plug
http://www.****.de/itm/121475862628?...%3AMEBIDX%3AIT
http://www.****.de/sch/i.html?_from=...zteil&_sacat=0
Sometimes it's a problem that the Chinese plugs are a little bit longer (but most doesn't matter)...RK3288 Devices
Originally posted by no_spam_for_me View PostThe stock one is 12V/2A using 5,5 x 2,1mm plug...
Stock PSU says 12V / 2A
V must be the same and A should be higherRK3288 Devices
Originally posted by no_spam_for_me View PostV must be the same and A should be higher
I've found a PSU from an old notebook with 12V /4.0 Output, connected and box turns on.
What apk can I use to stress CPU/GPU/RAM?
Danke
Edit:
I hate this f*** box again Box is freezing after about 2 hours using the 12V / 4.0 A PSU, im afraid i've to sent back the box.
Can you tell me how to proceed now.Last edited by bangsergio; 13 January 2015, 17:20.
"All Customers should contact our Customer Service Department for RMA before returning items"
I would say it's definitely DOA becuase you have the issues from the beginning...
If they don't react at Geekbuying.com , you should contact them here at the board.RK3288 Devices
There are currently 2385 users online. 0 members and 2385 guests.
