Hi bloatman, the ( MeeGoPad T01 ) can last 30 minutes with continuous film 1080p ?
Right Now, performance may be good, but is it the ( MeeGoPad T01 ) can suporter ?
you say, Bay Trail exceeds l'Adreno 320 = Qualcomm Snapdragon as the600 = Tegra 4, ...
You said, I will do tests, ...
In youtube, no video 1080P,...
finally the MeeGoPad T01, is good or no, for you ?
I briefly played youtube 1080p without any problem, my grandchildren kept playing the 10min big buck bunny 1080p 60fps over and over then finally I streamed a 720 movie. I'm mostly using hph-n6 box and this stick for my windows fix right now, pretty good combination
If you need a specific benchmark let me know
Could you measure with a A meter the power consumption of the stick when booted in to windows and idling around not doing anything.
also how good is your WiFi reception?
Can you install 64 bit build of windows on it?
