Cube offers what can seem like a bewildering array of tablets, including the standard Wi-Fi only Android tablets, the business-oriented iWork series and the cellular and phone-equipped Talk ranges. The T9 and the T7 are the latest offerings from the Talk series, although Cube did simplify their communication names. The 9.7-inch T9 reviewed here delivers a strong set of features and is a serious competitor for the Xiaomi M1 Pad and the Samsung Tab Pro 10.5. With 32GB of internal storage and full phone functionalities, the T9 costs only RMB1,499 ($244).
Cube T9 main specs:
OS: Android 4.4
Display: 9.7-inch IPS, 10-point multi-touch, IGZO
Screen Resolution: 2048 x 1536 (4:3)
CPU: MediaTek MT8752 octa-core processor (8 cores of 64-bit Cortex-A53)
CPU Frequency: 2.0GHz
GPU: ARM Mali-760MP2
RAM / Storage: 2GB / 32GB
Function: WiFi, Bluetooth 4.0, GPS, A-GPS, OTG, Miracast, FM Radio
WiFi: 802.11 b/g/n, WiFi hotspot
GSM: band2, band3, band5, band8
TDS: band34, band39
WCDMA: band1, band5
TDD: band38, band39, band40, band41
FDD: band1, band3, band7
Camera: 5MP back camera, 2MP front camera
Battery: 10,000mAh
Ports: TF Card Slot, SIM Card Slot, Micro USB Port, 3.5mm Headphone Jack
Weight & Size: 610 g / 237 x 170 x 8.9 mm
Design
The Cube T9 isn’t exceptionally thin and light, measuring 8.9mm thick and weighing 610g, it is much thicker and heavier than its predecessor – the Cube Talk 9X, which measures at 7mm and weighs only 560g. This certainly doesn’t give the T9 an immediate appeal, if you're making comparisons on these grounds. The reason why the T9 is so thick and heavy is that Cube uses both die casting roll cage and metal anti-roll frame, which are designed to protect the internals of the tablets from collision and impact.
The screen sits in a relatively thin bezel, which can result in unintended selections when holding the tablet in portrait mode. But while you hold it in landscape mode, there is enough bezel to rest your fingers on. The 2MP front-facing camera is located above the display, along with a tiny light sensor to help auto-adjust the brightness of the display.
The edges of T9 are silver-colored, which looks unappealing on our black review sample. In portrait mode, the top edge is home to the 3.5mm headphone jack and a micro SD card slot. The power button, the volume rocker slot are located on the top of the right edge of the slate, while the SIM tray is located on the bottom of the right edge.
The side-facing speakers are located on the right end of the bottom edge, which is pretty smart design as the speaker gates won’t be easily blocked by your hands however you hold the tablet.
The stippled plastic rear, which looks exactly like the back of the Samsung Galaxy Tab S, does the T9 no great favors, either. Although Cube insists that this design is inspired by the surface of a golf ball, and improves the grip of the tablet, still, we are not impressed.
The 13MP camera and an LED flash is located on the upper left corner of the rear side.
Overall, the T9 lacks the premium appeal the Cube Talk 9X was once famous for.
Display
The 9.7-inch IPS LCD screen is the same 2,048-by-1,536 resolution with 264ppi as the iPad Air, we can’t say we are astonished with this amount of pixel offering anymore as we have already seen lots of tablets from China with 9.7-inch Retina displays by now, and there are also lots of tablets with much higher pixel density on the market at the moment.
Unfortunately, the quality of the T9’s display isn’t as amazing as Cube advertised. The contrast ratio doesn’t match it is on the super clear PLS display on my Samsung Galaxy Tab Pro 8.4 and, with an explosion-proof film on top of the touchscreen, the display looks annoyingly grainy at times, especially when you are viewing a web page with white background color.
With that said, it is far from being a terrible display. Colors are a lot more relaxed than those seen on some of Samsung’s AMOLED devices, and viewing angles are also quite amazing.
The T9’s screen is fairly bright that we only need the brightness slider set at 30% or lower most of the time, the auto-brightness option works well too.
