you should connect it to an oscam server
Got my WeTek box!
@CodeRedin
you should connect it to an oscam serverWeTek Play
Recoveries: CWM | TWRP
Lollipop ROMs: CyanogenMOD 12 | OMNI | Android TV
KitKat ROMs: CyanogenMOD 11 | OMNI | ParanoidAndroid | AOKP
Misc: Unbrick WeTek Play
on android I know for sure you can connect it to an existing server, I don't know if the build included in that apk is pcsc enabled (so if you plug a linux compatible pcsc card reader you will be able to use it as a server in oscam), that can be surely done with openelec.
in this section there's a post with a link to that apk file that enables oscam, after that you can configure it from oscam's http interface, it will create the conf files by itself, I guess somewhere under /data/data or /sdcardWeTek Play
wetek
Well i have the ostool for android & the oscam server if that will do. I just need to suss it out. Do you no when you first setup the box & you scan for tv channels. Do you still have to manually put the frequency in your self, Or has that been fix. If not can you tell me the frequency for the uk sly thanks.
I have no idea, I scan Hotbird and have no trouble, in case if the frequency are not available you can do a blind scan, it will take longer but will workWeTek Play
All this dish, ATSC, headend stuff is totally beyond me!
All I have is Time Warner cable. It's digital so I do not even know if any of the WeTek options will work for me?
By the way, box is working great for me. Just played with the basic stuff. Going to be trying Kodi and what not later this week.
My wife got in a car accident Sunday so been a little busy dealing with that and out one car. She is fine but the car isn't...
Originally posted by Finless View PostAll this dish, ATSC, headend stuff is totally beyond me!
Originally posted by suzook View PostGood luck with your car, and hope the wife is OK. BTW...been using your ROMs on rk sticks. Wondering if you plan on anything on the wetek? Although Christian Troy seems to have a handle on the ROMs...lol.
I may do something but like you said Christian has a handle on this
I may look through the ROM to see if there is anything I can add.
There are currently 2115 users online. 5 members and 2110 guests.
