MBOX S82 + MELE F10 PRO = No internet (wifi)
    Greetings all. I just got my Mbox S82 and Mele F10 Pro. Unfortunately, these two devices do not work together well. I have tested this with lasted stock ROM and Finless 2.1. Both have same issues:
    1)- First and most important problem is that when Mele F10 Pro is connected to the S82, the Wifi Internet stop working (or very slow in some cases). There is no internet connection problem with any other USB mouse I use except Mele F10 Pro.
    2)- The second problem (which seems common) is the sound output not going through TV HDMI. This can be fixed in some cases by using Soundabout. But sometime it does not work and not sure what's wrong.
    Anyone having similar experience, please help especially for 1st problem which is very important.
    Thanks ahead.
    No body is having similar issue?
      Found the solution now. It appears that the USB dongle of Mele F10 Pro interfere with Wifi. Making the dongle far (using USB extention) from the device fix the issue.
      Hope this helps someone who have similar issue.
        2.) http://www.freaktab.com/showthread.p...and-Soundabout
        => https://play.google.com/store/apps/d...honeroutingfix
        RK3288 Devices
        - Overview BOX (LINK !)
          Thanks.
