Can someone give me a custom ROM and how l can install it? Thanks in advance..
l have MID - android Tablet PC Help please
Tablets and ROM's are like snowflakes...they are all different. They all require specific configurations depending on the hardware installed in them.
It might narrow down the field of alternatives if you can mention:
1. Brand/Model of tablet.
2. CPU Chip installed...Rockchip, Allwinner, MTK...what chip is it?
3. What version of Android? KitKat, Jellybean?
4. Size of the screen..7", 9.7", 10.1"...and what resolution?
5. How much NAND flash memory is installed...8GB, 16GB, 32GB?
Have you been able to find a factory firmware for it? Which custom ROM did you try to flash?
I've seen our developers do wonders...but we at least need some information to go by.Randy
Originally posted by rrileypm View PostTablets and ROM's are like snowflakes...they are all different. They all require specific configurations depending on the hardware installed in them.
Hi sir Thanks for answer. It is a cheap model and l have not much informationon the box it says Tablet Pc Android. and user manual says MID - android. before tablet had 4.0 android l think. size of screen l have looked it is 25 cm with screen in only screen something like 23 cm l think 9.7 inch. About memory l cant say anything
l have tried withROM name (A13)(T703v2-Q88D-V1.1). it stuks also.
Could you help me please. Thanks in advance.
It is like this https://www.youtube.com/watch?v=z_YMPvxsIJg
and l have tried this rom. https://www.youtube.com/watch?v=jZdp3im0Jas
I'm afraid you are looking for a needle in a very large haystack.
Maybe you can find someone else with this exact same tablet and gain some more information...or get a ROM dump from it.
From the looks of the firmware you were attempting to flash that this has an Allwinner brand chip. I'm not all that familiar with Allwinner. I've just now started learning the Allwinner architecture.Randy
Originally posted by rrileypm View PostI'm afraid you are looking for a needle in a very large haystack.
From the looks of the firmware you were attempting to flash that this has an Allwinner brand chip. I'm not all that familiar with Allwinner. I've just now started learning the Allwinner architecture.l want to make that tablet full rooted and basic android. Is this possible?
First you need to find the factory firmware to install on your tablet. Then, maybe a way to root will be possible.
Since you've erased the firmware, this will be a very difficult search. It must be the exact same firmware that originally came with the tablet.Randy
Originally posted by rrileypm View PostFirst you need to find the factory firmware to install on your tablet. Then, maybe a way to root will be possible.
Since you've erased the firmware, this will be a very difficult search. It must be the exact same firmware that originally came with the tablet.very very bad.. l will try to find it but as a newbie cannot find much on internet..
l have find my settings. Can you help me with this please?
This one.
Specificaties
Scherm 9 inch 5-point Capacitive Multi TouchScreen Processor Allwinner Cortex A8 1.2GHz+Mali400 GPU Systeem Android 4.0.3 Ice Cream Sandwich OS Opslag 512MB Ram, 8GB Nand Flash Operating System Google android 4.0 Scherm technologie 5-point Capacitive screen Scherm grootte 9 inch Resolutie 800*480 Harde schijf Capaciteit 8GB Camera 0.3MP Externe USB 3G dongle Audio Ingebouwde speakers/microfoon Geïnstalleerde software Youtube/Facebook/Twitter/MSN/Android market/ Skype/Calculator/Google Mail/Google maps/iReader/Quick Office Taal Nederlands Batterij LI 5000mAH 7.4V Werking met volle batterij 2-4U Poorten 1 x Mini USB 1 x TF Card slot 1 x DC jack 1 x Earphone jack WIFI 802.11 b/g Video AVI/RM/RMVB/MKV/WMV/MOV/MP4/DAT(VCD format)/ VOB(DVD format)/PMP/MPEG/MPG/FLV/ASF/TS/TP/3GP/MPG Audio FLAC/APE/WAV Afbeeldingen JPG/BMP/PNG/GIF E-book PDF/TXT
Please help
OK...that's good you've identified the tablet.
Now, you need to do some leg work in finding the firmware for it. Perhaps trying to contact the vendor and see if they have access to the firmware.
As I mentioned, you have an Allwinner CPU, so you will need a developer with Allwinner experience to help you with any customizations.
The main thing, though is to get the correct firmware for your tablet and flash back to stock. At least then, you can have a working tablet...and a stock firmware that can be tweaked.Randy
Originally posted by rrileypm View PostOK...that's good you've identified the tablet.
I would start with Elektrik. He's our resident Allwinner guy.Randy
It's good news that you've found a ROM that mostly works.
You just need to find one with the proper touch panel configuration.
Have you checked other things like wifi, bluetooth...etc..?Randy
There are currently 2060 users online. 3 members and 2057 guests.
