Xbox 360 Controller
    Xbox 360 Controller
    Hi all,
    I've just bought this TV box:
    MXQ Android TV Amlogic S805 4.4 Quad Core IPTV Box Media Player 1GB/8GB
    Does anyone know what I need to do to be able to play games using my Xbox 360 Wireless controller?
    The box has 4 Usb ports so plenty of scope for external stuff I thought ;-)
    Do I need another "usb transmitter" that links to the controller (like the one I've got with a little keyboard I bought)?
    Or is it more techy than this? Do i need a Rom or Kernel (whatever they are)?
    And, yes, I've looked around on this forum, but just confused myself!!!
    Also, is there a compatible Retro Game emulator for Sega, Nintendo etc?
    Cheers in advance,
    Stu
    You would need one of these as a starting point http://www.amazon.com/Xbox-360-Wirel..._1421145036813
    I have no experience with it or your box but quick google suggests these work with some Android devices at least.
      mmm, interesting, thanks
      here's a cheaper one on **** under £5 :-)
      http://www.****.co.uk/itm/4-PC-Adapt...item58b72e16af
      ^^^ Has anyone else had any success with this setup? ^^^
      I was half thinking of just buying a cheap 360 wired controller and trying that
      would probably alleviate any delays on button responses as compared to wireless setup?
      http://www.****.co.uk/itm/USB-Wired-...item35e369c504
      not sure, yet...
        You yourself can find it from **** or Amazone easily.
          Yes, I've already found some (as in my links above), but what I want to know is DO THEY WORK, before I waste my money?
          Somebody must have been there, done that, already...
            Well, after much much researching, I've ordered a Tronsmart Mars G01 for £16.99
            http://www.****.co.uk/itm/Tronsmart-...item27f61a17af
            Will update this post if/when I get it working...
              Hi Stu, how are you getting on?
              Oh thanks for asking, great thanks, you?
              Yeah good.
              Well I can confirm that the pad works perfectly, for those of you who are interested...
              That is all.
