P2P streams crashing my M8?
    First up thanks to Bob for rhe 1.8 rom. I bought my M8 off **** just before xmas and it just didnt cut it.. It had a K200 rom on it and after some research found my self here, installed the 1.8 rom and its been great.
    On the new install rom I installed Kodi 14 and all seems well.
    However, recently I've installed and configured the p2p streams and ace engine.
    When I go into p2p and the parsers and find a channel it boots up well and starts playing, then after about 30 seconds it freezes. If I press the square stop button on the player it crashes Kodi and goes back to the app screen. If I'm really lucky it crashes to a black screen and I have to disconnect the power to get it back. If I press the stop button dureing playback (before it freezes) the player hangs there for ages and I cant go back or do anything with it apart from unplug the power
    Whats wrong here? Seems a shame as the quality of the feeds is very good!
    thanks,
    Steve
    thanks,
    Steve
    this post belongs in the xbmc section of this forum, i think it more related to kodi go back to gotham 13.2 or spmc
    Bugs are Sons of Glitches!
    JustMe
      Ok, now running TVaddons 13.2 alongside kodi on the box.
      Downloaded the windows version of Kodi for my pc and they all do the same thing. Open the stream, play for 10 to 30 seconds then freeze and xbmc/kodi closes or crashes the box to a black screen.
      Disconnecting the power is the only to rest..
      Must be some setting somewhere??
      Steve
        Steve
        I use JustMe 1.6b and same thing happens.
          Go to add-on setting, locate acestream advanced settings set live buffers to 30, VOD buffers to 10 and disable the kill acestream engine selection button. This will fix your issues
          thanks,
          Steve
