I have been using VMLite VNC server on all my Android devices. It is the only one that doesn't require a root. You do have to start the server from a PC or Mac if the device is not rooted. Unlike TeamViewer, VMLite VNC server doesn't need authentication or be active. It can run in the background. You can also connect remotely (outside your network).
