Patch FM for Talk 9x
    Hi
    I see in 4pda forum link for FM Patch to use it without earphones
    but i'm unable to download it
    Anyone could share it please?
    Thank you
    Something found
    I tracked the links from 4pda.ru to forum.china-iphone.ru. I registered to the forum and downloaded the zip file. Then I uploaded it to here. I don't know that is the file for Talk 9X or just the source file. The file size is same than in 4pda.ru (481.16KB).
      Thank you i will test it
        Did you already test it? Does it work with Talk 9X and what rom you are using?
          I tested it. It "works" (i can ear noise from speaker) but while i don't have antenna, i can't hear radio station.
          I'm on V2.0 stock ROM (20141111) root, brightness patch, 6go appsize
            What I have heard you have to be near radio tower to make it work without antenna. But you can also use old earphones and cut the wire as short as you can. First cut it to 1 meter for example and then shorter and shorter. I have seen only couple centimetres long wires. Longer wire = better antenna.
