CX-919 (RK3188T & RTL8723BS) problem after flashing - bricked or wrong firmware?
Hello. I have a CX919 TV stick (RK3188T & RTL8723BS) and after flashing this stock firmware from here using Rockchip Batch tool, the stick wont boot. Maybe the firmware is wrong,maybe i have made a mistake somewhere.. Can you give me a turorial on how to flash my device properly? Can you give me a suitable firmware? Does the stick have to be connected to HDMI port all the time during the flashing process?Tags: None
Exactly
What firmware WAS on it Jellybean or Kitkat?
What firmware did you try to flash to it?
How did you attempt to flash it i.e. what flash tool and what buttons did you click?
IF you alreay had a version of KITKAT and you tried to flash a JELLYBEAN firmware, there are steps to take to get it back from not booting but anyone that can help you will need this info.FLHT = Harley
HEMI = 2010 Dodge Challenger SRT
Cause I've been asked.
I've this problem with another Android Stick. I tried an KitKat rom (that dosen't support my device) and now that I flash back a JellyBean ROM i'm stuck in boot image...
Can you explain what are the step to do to get back to JellyBean?
There are currently 6807 users online. 0 members and 6807 guests.
