Any Finless ROM for iMiTO MX1 ?
I will be doing one this week now that final mk808 is done and my 1.6 ug802.
I find the NEW firmware for MX1, but i don't know how to update
http://blog.geekbuying.com/index.php/2012/11/06/imito-mx1-dual-core-mini-pc-1106-new-firmware/comment-page-1/#comment-205
But i like finless rom it very easy to flash and finless rom is rooted !Last edited by andychu22; 06 November 2012, 10:25.
some problems on the Imito mx1 after update
I ran in to some difficulties when i tried to update my Imito MX1 so i thought i would share them.
1st problem i had was that i run 64bit and didnt understand to use the folder that said AMD64 cause i have intel but when i tried that it found the device.
2nd problem was after i upgraded the firmware the wifi connection found the router but it newer got the ip address so i just upgraded the firmware once again but it seams to be a problem again when the device has been turned on for a while.
3d problem i havent found the solution on yet but when i try to stream a movie and that works great by the way but then u run in to the problem and that is when u try to stop the movie or back out from the film the device will reboot and then the wifi and the bluetooth wount work so then u will have to disconnect the power to reboot it again and then its back as usual.
4th problem is rooting every guides doesnt say u have to switch back under storrage to >Media DeviceMass Storage< cause then the Moborobo program wount find the device.
thanx and that was the problems i ran in to
There are currently 4767 users online. 0 members and 4767 guests.
