I want to connect a Box TV B368 RK3288 to use with an HDMI projector, and play the sound to an old external sound system that has RCA input only.
The problem is that the BOX TV has HDMI output, AV and SPIDF. http://www.geekbuying.com/item/B368....TG-329828.html
My intention was to send the image to the projector using the TV Box´s HDMI output, and send the audio to the external stereo using the AV output (whith AV to RCA converter).
In another forum I readed that if I connect the projector with HDMI, AV output does not work only for audio. HDMI and AV will dispute the image output and one of the two would not work.
Is this correct?
If it is not even possible to pass only the sound by AV output, i understand that the solution would be to purchase a SPDIF to AV converter. Is this correct?
Any other ideas?
I acquired the TV Box today and will receive it in a few weeks. I want understand what will I need to go now to prepare the room or acquire equipment needed.
I appreciate any help.
Bye,
Tulio Bretas (and Google Translator)
