i have actual Wasser Firmware 2.0.3 installed, but my 64gb sd-card (exFat) is not working and i cant write on it
But my 32gb scdard works ...
Is there another Rom wich supports sdcards with 64gb exFat or a way to enable support in wasser firmware ?
