Buying a player today UG007 vs MK808
    I want it to be my all around HTPC for on the go. Netflix, amazon, hulu and plex. Which one is the better option. The UG007 seems like itd be cool for bluetooth so I could play games with a ps3 controller but is the latency too high? If it is I dont really need bluetooth because thats all id use it for.
    Which one should I go with. Which has a bigger community behind it for roms and modifications and such? Which is more powerful?
    EDIT: Pretty much what Im asking is seeing as their specs are basically the same is there something the specs dont tell you like bugs or app issues?
    The biggest issue with these devices is the WiFi. I have a MK802 and a MK808, which both have huge issues with dropping network quality, and even completely losing connection, being unable to reconnect, when no other device in the house have this problem. Wouldn't really recommend it, unless your router is right next to your TV, or you're using a ethernet solution. I haven't seen any tests of the UG007 WiFi yet, or the quality of their built in bluetooth, but my guess is that there'll be a few more tests within a week or two.
    I ordered a MINIX NEO G4 a few days ago. MINIX claims that the G4 don't have any of network issues that the other sticks have, and that their ROM is not a half-assed unstable ROM with crappy apps preinstalled on it. Comments on their facebook page seems to be mostly positive too (https://www.facebook.com/minixtech I could possibly give a small review on it when I receive it if you're interested.
      Hi Mow,
      What's your verdict on the G4?
      wifi and everything?
