[Pipo Project] Ultra U8
    In development
    Please post DMESG if you have this device
    Donate to Finless
    Do you still have the one I sent you previously? I think it's still on my Google Drive.
    Randy
      I can't find where you put the link to that test kernel for me to try.
      Can you post it here?
      Randy
        Here is the dmesg I posted earlier:
        Remember, this tablet has a 768x1024 portrait resolution.
        Randy
          Last offer as I sign off.
          I've recompiled with the U8 LCD driver compiled and a guess at the correct header.
          1.01
          Donate to Finless
            Thanks, Darrell!!!!!
            I just boxed up my U8 and sent it to Abdul_pt today. He should have it by 2/3...if UPS can find Portugal ...the ladies at the office were quite confused as I was filling out the label...and so was I.
            Randy
              Abdul (or anyone!),
              Can you provide a GPIO dump for the U8?
              Donate to Finless
                Was busy.
                Check here - http://paste.ubuntu.com/10744368/
                Your latest build, 1.01, i have no image on display. It boots, and i have ADB for a short period them it hangs and i have to use HW key combination to flash it back.
                if [ $up.post.type = $type.two.lazy.to_use_google ] || [ $up.post.type = $type.silly_question ];
                then mv $user.contact.up.post /.trash; set response($response.type = ignore);
                $user.up.post.ignore_in_future = true; fi;
                  OK so ....
                  LCD Backlight:
                  BL_en set as 0-A2 (yes)
                  SSD2828 MIPI:
                  Reset 0-A7 (yes)
                  VDD IO 0-B0 (no!)
                  shut 3-D4 (yes)
                  spi_miso 0-D4 (yes)
                  spi_mosi 0-D5 (yes)
                  spi_sck 0-D6 (yes)
                  spi_cs 0-D7 (yes)
                  Donate to Finless
                    The same behaviour than previous version.
                    Backlight is on, but no image on display.
                    dmesg
                      dmesg
                      Can you do a GPIO of my kernel to compare?
                      Ahh! I see the problem!
                      <4>[ 0.892421] load mipi dsi chip:ssd2828 id:2828 <3>[ 1.002115] request lcd cs pin fail!
                      Donate to Finless
                        Here's a dump from your kernel - http://paste.ubuntu.com/10750364/
                          Please try 1.01.02 and provide dmesg / GPIO. I suspect it still won't work screen wise and the TS is not going to work either.
                          Donate to Finless
                            You were right. Nothing changed
                            dmesg - http://paste.ubuntu.com/10751927/
                              Still no image.
                              dmesg - http://paste.ubuntu.com/10752923/
