CS918ii - easy questions
    Hello
    Sorry, noob here...
    How can I go into the bootloader or recovery mode on this device ?
    What full backup solution can I use ? I don't have much space free to create the backup so I would like either to have it stored online OR be able to backup only ROM (not apps).
    Thanks in advance for the help
    roms files thools
      Thank you for your answer but my device is CS918ii not CS918S. It doesn't look to be the same.
      Also I am not looking a tuto for changing ROM but actually asking how to go in bootloader mode.
      As a side question what full backup app I could use with the problem of limited space available.
      Thanks and regards
        If your rom is rooted
        RK3288 Devices
        - Overview BOX (LINK !)
          Thanks for the answer. I saw this one but the goal was not to go through an app, but more for the case I COULDN'T use an app (couldn't boot).
          I got it by myself: There is a small hole, but I didn't find it to work for anything.
          But there is a button under the box -> long press 10 seconds -> goes to bootloader mode.
