2- Buy from a seller who provide external anntena in the pack or you are lost. Can get from my seller (a major sponser from here...) imito factory tell that they didn't produce anymore
3- Major mounting default from factory on all unit. i got problem with micro usb power connector, i open the case and see that the two pin that retain the connector is not fix in the board hole and and soldered. The connetor was moving due that only 5 mini very small retain the plug. i broke mine and have to glue with epoxy to have contact from connetor to board.
4- Think twice, there's no OTG PORT. EVENT WITH A POWERED a all-in-one asix rj45 + 3 port usb hub. device won't boot.
5- Otherwise it is a really fast unit and wifi speed is better that i get from any other tv stick i own. event without antenna....
6- Good aluminium desing that help to spread heat from cpu
7- Bad rda bluetooth chip or antenna; even rk903 chip havemore power, perform like class 3 . when major factory will they provide a descent bluetooth v4.0 broadcom or csr or issc chip real class 2 ??? AND DESCENTS WIFI AND BT ANTENNA into tv sticks ?
Leolas and his friends have working hard to provide greatest roms and oc kernels
greatest thx
