[Pipo X7] OS - Linux
Fedlet boots on my X7 https://www.happyassassin.net/fedlet...trail-tablets/
I dd-ed the ISO to a USB Flash drive on my Mac, booted with F7, selected my Flash drive as my boot device, and it booted.
Haven't had time to play very much - and no sound devices appeared to be installed - and whilst it recognised the cabled network adaptor (which is a USB device I believe according to Windows?) I didn't get an IP address. However I'm in a new location at the moment (long story) so may need to reboot routers etc.
Encouraging though.
The Ubuntu Mate LiveCD in the Meegopad section also boots (I had to create the live stick using Rufus in Windows) - albeit with a splash screen error you have to accept.
This let me install Kodi Helix (it has XBMC Gotham installed already) - and I get incredibly low reported CPU levels when playing 720/50p with VAAPI decoding, however I only get 30fps on a first attempt... Wifi works, but no wired ethernet.
***EDIT - however the filing system isn't persistent - so nothing lasts past a reboot... ***
Maybe 'LinuxLive USB Creator 2.9.1' ?
http://www.linuxliveusb.com/en/other-versions (Portable)
and try to use http://www.linuxliveusb.com/help/guide/step3RK3288 Devices
- Overview BOX (LINK !)
Originally posted by noggin View PostOr if a couple of us here fancied sharing the purchase to get one to linuxiumOriginally posted by doublea View PostIf you're able to post a Donate link, I'm in for $10 and I'm sure another 10 users would be up to doing the same to get you a box.Originally posted by rrileypm View PostThat's right, Linuxium....If you post your Paypal link...I'll spot you $10 or so. We really need to get you one of these boxes.Originally posted by noggin View PostMe too.
but I think you should write him, why and for what you donateRK3288 Devices
I've managed to get Ubuntu 14.04.1 booting from an external USB stick (though my total inexperience with GRUB etc. means that the booting requires a second USB stick)
With no additional drivers I've got cabled Ethernet running fine, but I'm using an external sound card. Kodi works FAR better under Linux than under Windows for video playback.
Files that were skipping and dropping like mad in Windows are smooth as silk under Ubuntu - with no additional cooling required, though dmesg does report thermal throttling.
I've started another thread about it.
Originally posted by no_spam_for_me View PostI don't know if it is already fixed by e.g. Gearbest or Geekbuying, but here you will find the Donation link
Guest
So you believe the propaganda of Minix??
They told more things in the past which were not true..
MLC vs. TLC http://en.wikipedia.org/wiki/Multi-level_cell
PiPo use the Samsung KLMBG4GEAC-B001 (http://www.minimachines.net/a-la-une...low-cost-25383)
=> https://memorylink.samsung.com/ecomo...SetLabel=e-MMC
==> Class: eMMC Pro Class2000 eMMC Version: eMMC 4.5
BG = 32GByte
4 = NAND4 + Microcontroller
G = ??? (so maybe TLC ???)
E = Vcc=2.5V to 3.6V, Vccq=1.65V to 1.95V, or 2.5V to 3.6V, dual mode
A = S3C49RAA01
C = ???
If I look at the Samsung TLC pdf, then I found KLMBG4GEAC http://www.samsung.com/global/busine...Final_HR-0.pdf
But I don't know which chip MINIX use at there pcb...RK3288 Devices
There are currently 1592 users online. 0 members and 1592 guests.
