Guide to make WIMBoot images -
[Pipo X7] OS Official Windows 8.1
Originally posted by WeK05 View PostThese devices do not have the traditional Windows installation. They use WIMBoot images.
http://technet.microsoft.com/en-us/l.../dn621983.aspx
Today i try to install this windows 8.1, and make it work, here is some tips:
1 download such a large file from the baidu.com is a pain for you guys, but have no other choice right now, you should download the whole 8 zip files (from part 1 to part 8). the whole system is about 4.9G, they have to split to 8 files for uploading...
2 decompress the file , you just need to click decompress the part 1, and it will automatic decompress the whole 8 files. and then you will find a folder called x7.
3 now prepare a usb driver (at least 8gb) and then format it to NTFS and change the Volume Label to winpe
4 copy the whole files in the X7 folder to the root directory of 8gb usb driver
5 insert the 8gb usb driver to pipo x7, power on x7, and press F7 button, choose usb driver recovery.
and the system install will work.
I will write a step by step instruction in my blog.
i have checked, they system still activate after i reinstall the system, seems they have written the key to the BIOS. so no worry about the windows license.
Eric
GeekbuyingLooking for developers
Eric
Geekbuying[/FONT][/COLOR]
All of the sections there say "Not Installed"
So this leads me to believe there are no keys in the BIOS yet Win 8.1 with Bing does not need activation.
Originally posted by Finless View PostWhen you go into the BIOS under security>Key Management
BobTo Infinity and Beyond.... XBMC
Hehehehe.... I already had that tool but had not used it yet.
Yes there is a key showing! For me it's the same key that I dumped in this thread in step #4
Also I installed windows 10 preview and it is not asking me to activate and enter a key which on the windows 10 download page a different key was provided. Again I did not need it.
Interesting!
So what are the BIOS keys?
Originally posted by Finless View PostHehehehe.... I already had that tool but had not used it yet.
Interesting!
The reason windows 10 is probably not asking you is because it only needs a test key to install and not a proper activation key as it is only a time limited demo, your key is probably working fine for it.
The embedded key will not activate any other version of windows tho except the exact one that it came with.To Infinity and Beyond.... XBMC
Originally posted by Flumpster View PostThe key it is showing you in that app is your activation key embedded in the bios.
Flumpster, that RW tool..... I am new to using it. I see it can save a dump of this stuff but can it write? I cannot seem to see where to make it write.
What I would like to do is erase that key and test and then put it back if needed.
Originally posted by Finless View PostThat explains why when I installed a retail 8.1 Pro that I have, I had to use my own key. The installer asked for it up front and then I also had to activate online.
Originally posted by Flumpster View PostI have nothing here I can try it on sorry Bob and the last thing I would want is to break yours. If my machine comes this week I will test it myself but if not then I will be seeing my mother next week and will be able to test it on her laptop which has an embedded code. It shows nothing on my main PC.
But it appears this RW everything tool will not write to the BIOS?
I turned off BIOS write protection in the BIOS and same thing.
So it appears to change that key, you have to flash a modified BIOS which right now, I have no clue how to do that. The AMI BIOS web site provides tools to work with AMI BIOS and it looks like you can use a tool in Windows, DOS, etc.
FYI on this page there, I checked and this box uses an Aptio BIOS. The link is Aptio 4 but out BIOS is version 5.
At your BIOS thread I gave you a link to an older tool... the latest which I can find at the net is AMIBCP 4.55.0070... but not the latest 5.0...
But I think you need a bios-update-file at which you can work with that tool, and I don't know how to dump this kind of the flashed bios... maybe RW everything can help?RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostI don't understand your problem... at first Link you see that these tools are for 4 and V (which I think is 5)...
Originally posted by neomode View PostCan someone make me a Dump of the Bios please?
I have the Program to Mod the Bios.
Will also upload to FT Server.
Neomode
There are currently 2019 users online. 3 members and 2016 guests.
