FW: MXIII_111k4 1+8&2+8通刷.img 174226 20150112
Originally posted by vermillion View PostFlashing now. If like me you get error: parse burning image fail. Rename img file to something like MXIII_111K4.img that worked for me.
unfortunately No Bluetooth.
The reason I would like flash because my box came with 110k4 and kernel is Oman@ubuntu. The screen is flicker non stop. I change few hdmi but still the same. hopefully 111k5 help with the screen flicker
Originally posted by cat2115 View PostDo you flash with sdcard or Windows? I have Windows 7 x64 and my windows did not find driver for the box. I did install Moboro but still no help. Please guide me how u flash or where u get windows 7 driver for the box.
Begin with no power attached to box.
Start burning tool
Load image file to burning tool. Wait for it to accept. If parse error, try as posted above or look for another img.
Connect USB cable (still no power on box))
Toothpick time - press and hold (still no power applied)
Connect power cable (keep press and hold of toothpick)
Press and hold power button (now with toothpick still preessed)
Burning tool would then recognize and connect.
Press start on burning tool
One other strange thing with mine. The burning tool would only be successful if connected to usb 1 (first line on burning tool). Any other would result in a fail of some sort.
Good luck
There are currently 1177 users online. 2 members and 1175 guests.
