Firmware-compatible devices Rikomagic V5 / Jesurun T034 / (Hindo) CS008 and maybe Ugoos MK809V and Vigica VG328
I bought some anonymous $62 CS008 aliexpress device, i had some problems with firmware and i discovered that on my device runs firmware even from Rikomagic.
Blogger ist ein Veröffentlichungs-Tool von Google, mit dem du ganz einfach deine Gedanken der Welt mitteilen kannst. Mit Blogger kannst du problemlos Texte, Fotos und Videos in deinem persönlichen Blog oder deinem Team-Blog veröffentlichen.
It's a Rk3288 Mali T764 Box tv
No, you talk about a box, this thread talk about a stick... I gave you an answer at your other post (seems to be a Q8)...
Press and hold the Reset/Recovery button (little hole on back) and connect USB cable to the computer (OTG port; no DC port).
I have the CS008 and I did try to use the last firmware from Ugoos but WiFi and Bluetooth are no working. Original firmware (date 2015-05-19) only support 720p. Do you know a firmware working good with 1080p support?
