I will add to this list as I go and remember what I like to do
1) Hate having to login (enter a password) every boot? You can turn that off and retain your password.
Press the windows key and R key.
Type:
control userpasswords2
On this dialog uncheck the box that requires users to login to use this PC.
2) Hate booting to the Metro Launcher every time? You can boot to the desktop instead.
On the bottom bat right click and select properties.
3) Hate the gyrations you have to go through to shut down or power off? Well these little gems I made myself. THEY ARE NOT PROGRAMS! You do not install anything. They are simply short cuts that will call the system to shutdown or reboot.
Download this ZIP
https://drive.google.com/file/d/0B9B...ew?usp=sharing
Open it and copy these short cut icons to your desktop.
Use as you please
More to come,
