CUBE TALK9X U65GT_V1.9W_orang_150118_Lepi
    Including the tablet with serial number lower than B1427XXXXXXX!
    Serial number can find on the back cover at the bottom near the connector Micro USB.
    Hi, my friends. I publish new mod white version U65GT_V1.9W_en_orang_150118_Lepi
    List of changes in relation to U65GT_V1.8.8W_141226_mod Lepi
    1. Improved white theme in orange design. Fixed many bugs interface type "white on white".
    2. Added MultiUser by default and modified Engineering menu. Now tab Band Mode and others do not hide mode MultiUser.
    3. Added support for NTFS (instant mount) from noirix.
    5. Added libs against stuttering sound in the online video viewing. Thank cherva70.
    md5: d115a3a09e30b69e3937e71c35b14933
    Installation Instructions:
    Theoretically, the update can be installed on any of my manufacturing 1.8.x, but I did not check for the temporary absence of the old plate.
    The patch update is made only from modrecovery CWM or TWRP. Archive update put in the root internal or external memory (can be in any directory with the Latin name). Boot into recovery. Make a backup of the current mandatory firmware, it is better on a memory card.
    Then select Install (TWRP), specify the path to the file and firmware swipe confirm the firmware process. Wait for a successful finish and boot the system. Make settings by yourself.
    In CWM to choose Backup, confirm, wait for the finish line backup. Default takes CWM archives firmware with an external memory card, so to flash through CWM put the file on an external SD.
    I propose to put the update over 1.8.x, wipes are also not impossible to do, or do not have anything to put the update! Is that wipe Dalvik Cache.
    There are no guarantees! Risk and assumes responsibility fully by the user.
    Preliminary backup is required!
    Successful upgrade!
    videoTutor1 videoTutor2 videoTutor3 videoTutor4 videoTutor5 videoTutor6
    TWRP_2.8.1.0
    TWRP_2810_newTheme TWRP_2.8.5.0
    PayPal donate WMID410517421626
    Great work Lepi!
    Thanks for your support to V1.8 rom also! You have ported the gestures already from V2.0 to V1.8 which is amazing. Is it possible to port double-tap wake up to V1.8?
    The orange is also looking good. I checked the pictures from 4pda.ru
      No, black gestures in this version does not work. Sorry.
      TWRP_2.8.1.0
        What do you think? Is it any way possible to make black gestures to work in future?
          I think that the support of black gestures founded in the kernel. No accident that this feature has appeared only in version 2 with the new kernel. IMHO
          TWRP_2.8.1.0
            I think that the support of black gestures founded in the core. No accident that this feature has appeared only in version 2 with the new kernel. IMHO
            Thanks for your answers. So I think it is kernel based feature and needs custom kernel for V1.8. White gestures are good for now
              How can I install your rom?
              I currently have the July rom from Brian: 900Supersport rom (based on official V1.8 July rom)
              Should I first install your rom U65GT_V1.8.4_20140930W_en_mod_Lepi, then the last mod: v1.9.0 white theme with orange color?
              If so, can I do so easily from my current rom?
                Theoretically, there is no obstruction. You can experiment and put on top of the firmware Brian. It remains to try and tell us happened to install or not.
                TWRP_2.8.1.0
                  Great job Lepi!
