If you could kindly provide the names of sdcard 64 GB on the cube talk 9x?
Working 64 GB SD cards on cube talk 9x
Can someone explain how to format a 64GB, I looked into TWRP and it shows/asks me :
Size: EXT Size, Swap Size
File Sysyem: EXT3 or EXT4
What must I select.
EXT Size, is this the size of blocks or the partition size, is it Byte, MB ?
Is there a way to jump to max, elde if have to touch the button 100s of times.
Do I need EXT3 or 4.
I bought a Samsung PRO SDXC UHS-1, read 90MB write 80MB
Thanks for help.Last edited by mr..speed; 21 January 2015, 23:37.
Originally posted by mr..speed View PostCan someone explain how to format a 64GB, I looked into TWRP and it shows/asks me :
What must I select.
Thanks for help.
SDXC support
Originally posted by Scorpion1983 View PostI think 64 GB is the Limit. 128 GB, mhh i donĀ“t think so, that it will work. But you can try it.
If you format your sd-card to ext4 for example it is not SD-card anymore. it is only memory card. SD name is licenced by Microsoft. That is why some Chinese companies use TF-card name. TF is not licenced.
Originally posted by Vohukain View PostJust google it: "how to format sd-card". I would recommend you to use minitool partition wizard if you use windows.
Originally posted by ttca View PostI have installed Lepis V2.0 Image from December, but when I stick in SDXC 64gb formated on the pc with exfat or ntfs, filesystems are not recognized.
Is there any possibility to use exFAT or ntfs for the microsd slot?
Originally posted by Scorpion1983 View PostI think 64 GB is the Limit. 128 GB, mhh i donĀ“t think so, that it will work. But you can try it.Originally posted by Vohukain View PostCube Talk 9X has SDXC support so there is a change that 128Gb is also supported. I haven't tried because I don't have that big sd-card. But after all 128Gb should be working at last with other format (ext2/ext3/ext4 etc.). There isn't actually any hardware limits for bigger sd-card. It is only software problem and what licences Cube has paid.
u65gt has SDXC support, so theoretically can support up to 2Tb microSD card!if you appreciate my efforts this is the link for any donation:
Different tablet!
Originally posted by maxecume View PostI've just ordered my microSDXC 64Gb for my T9.
I think I will have to re format it... I trusted you...
There are currently 1373 users online. 1 members and 1372 guests.
