If you need what mine are set to, let me know.
I have not yet tried all this to see what temps I am getting but one thing I do not like is how this is heat sunk! These thick thermal pads to thin metal just do not cut it!
Improving that I am a little worried about. This is because this CPU has no case on it! When you pull the pad your looking at the raw silicon! So using something like Arctic Silver to attach a heat sink might kill the damn thing. Maybe some non-conductive thermal epoxy will work.
