Did I waste my money??
    User error.....got it working very nice now
    What a waste of money
    What hd stuff are u streaming? I think the android boxes are ok.atm streaming nba game time which is hi def.smooth as butter using wireless.i also always play 720 p videos off of YouTube.
      Your using a wetek play????? Show box app, and vudu. Stuttering nightmare using wired ethernet.The interface is laggy too.I thought I was upgrading my rk3188, but I was horribly mistaken.
        The 8726mx is a rk3066 competitor, it's obvious that it will be inferior to the rk3188.
        I'm sorry that you feel like that.
        WeTek Play
        Recoveries: CWM | TWRP
        Lollipop ROMs: CyanogenMOD 12 | OMNI | Android TV
        KitKat ROMs: CyanogenMOD 11 | OMNI | ParanoidAndroid | AOKP
        Misc: Unbrick WeTek Play
          I jumped the gun. Didn't realize that.Gonna put this up for sale. What's the best media player/streamer box or stick out there now? Would appreciate your opinion.
            I really don't know, I'm biased toward amlogic products.
            WeTek Play
              I'm using cs4k(3288)people on here say the minix and ugoos ut3 have good support but no hi def on netflix.pipo x7 has windows 8 .1 plus hi def netflix according to bob.fire tv seems pretty good too.it played well when I had it for a while.(tested for bro)
                Thanks...did some reading. Got it running smooth.
                  Hope to see you again with possible future products
                  WeTek Play
                    How about coming to the dark side??? Rk 3288??? Lol.
                      What version of official android you was testing? Netflix HD works fine, also NBC Live Extra addon for Kodi/XBMC.
                      You should check your internet connection, here all fine
                        I simply hate Rockchip. They could think they are the Chinese Intel... well they are not, and I'm glad that Mediatek took them the lead.
                        WeTek Play
                          Which device are u playing netflix hd?
                            Tell us how you really feel...lol. Jk.
                            BTW, do you think 4.4 runs any smoother??? Just curious.
                            Update....kitkat runs MUCH better.
                              I guess your Lollipop issues are caused by the bold thing wrote in the OP of CM12/ATV builds: it uses ART so if dex2oat is running in the background EVERYTHING will lag, at first boot play store and play services (103MB package so compiling it takes a lot on the MX, like 2/3 minutes) will updated, and they will pretty much every week.
                              You should just relax and let it settle for an half hour, disable play store updates for regular apps and update them manually, knowing that you can't do anything while art compiles the apk.
                              Actually L runs much smoother than KK, unless dex2oat is doing stuff in the background, that's Google's programmatic obsolescence I guess
                              WeTek Play
