HPH lesson1_How to build connection between LeHome and HPH
    LeHome assistant is a new app we Nagrace developed to remote the TV box through your phone.
    There are two ways to build the connection.
    1. wifi
    In wifi network ,both Android and IOS devices are available to use LeHome.
    Step 1:
    Make sure that your phone and HPH are connected to a same wifi.
    Step 2IOS device jump to step 3)
    Launch LeHome-->Menu-->Setting -->Connection Mode -->wifi
    Step 3:
    Menu -->Device Connection -->searching -->choose HPH
    Step 4
    Menu -->choose the function you want
    2. Bluetooth
    Because of the deference between Android and IOS, for IOS device , can’t build Connection through Bluetooth .
    Step 1:
    Make sure your devices are paired through Bluetooth .
    Step 2:
    Launch LeHome-->Menu-->Setting -->Connection Mode -->Bluetooth
    Step 3:
    Step 4
    That all about how to build the connection better LeHome and HPH.
    Next time ,I will provide more information.
    1. wifi
    Step 1:
    Step 3:
    Step 4
    2. Bluetooth
    Step 1:
    Step 2:
    Step 3:
    Step 4
    Thank you Jack for the explanation
