Advice on new android box
    Hi im thinking buying one of these
    RKM MK80 Plus Allwinner A80 Octa Core 4K Media Player 4G RAM 32G*
    Are they any good and where is the best place to purchase from. Im in the uk and dont fancy using **** as dont trust anything I buy from there anymore.
    Thanks in advance
    RKM MK80 Plus A80 Octa Core 4K Media Player 4G RAM 32G*
    Thanks in advance
    I have a RKM v5 Witch is nothing like the RKM MK80 but i do like the RKM brand it is quality..
    There are many place's you can buy the RKM MK80 from.
    Direct from RKM
    http://www.aliexpress.com/store/prod...240219029.html
    Geekbuying
    http://www.geekbuying.com/item/RKM-M...ck-339721.html
    Gearbest
    http://www.gearbest.com/tv-box/pp_13...FeISwwodejMA2g
    Usellisell (Good chance of uk stock so no customs duty to pay but check there is uk stock first)
    http://www.usellisell.com/riko-mk80-...droid-box.html
      Thanks think i will give usellisell a go
        Ok so ordered one today. Got it for £125 delivered with the freaktab 5% discount.
        Are there any custom roms for this yet?
          Select as you need
          You can one TV box as you need, PVR, a key to clean up, parental control, 4K, etc.
          My new box has a lot of functions, but I can not use them well, I do not need them either.
            The MK80 uses the same pcb like the Tronsmart Draco which you can find here at this sub-forum where I moved your thread to...
            We also tested MK80 rom at the Draco...
            RK3288 Devices
            - Overview BOX (LINK !)
              Sorry but dont quite understand your post.
              I get that they are the same pcb. All I want to know is if you guys have done a custom rom for it. Is the rom needed or is the stock rom good enough. Is this box any good. Cant seem to find alot information about it on here. I only really trust you guys on this forum.
                Hi there as the rkm is the same pcb bored as the draco you can use draco roms on it
                Finless rom here
                A cool thing about the draco & rkm A80 is the can flash a custom rom to a sd card and boot from sd card so you dont have to remove the stock rom if you dont wish too.Look here
                I have the stock rom on the device it self & the finless rom on a sd card "PERFECT SETUP", so if want to boot finless rom I put the sd card in & for stock rom I remove the sd card
                  Finless rom here
                  Ok cool. Like the idea of being able to boot from sd card.
                  Whats your opinion of the box? Are they any good? I read somewjere about being able tor ubuntu on them aswell
                    I have the draco & I rely like it very fast & I love to boot from sd card I flashed finless to a 32GB sd card so i have plenty space & like i said i still have the stock rom on there untouched
                    As for Ubuntu/Linux its still a work in progress i think it will come soon enough, i dont rely much about it look hear
                      http://www.freaktab.com/showthread.p...t-s-talk-about
                      Ok bud you have been really helpful.
                      Thanks for your time. Just got to wait for it to arrive now so I cant get stuck in
                        MK80
                        Here is a new ROM for MK80 01.08.2014.
                        Anybody who opened Draco or MK80, what is a name of PCB?
                          Hi where did that rom come from?
                          It is not on there website?
                            On Russian forum:
                            В шапке, прошивки сторонних производителей.
                              Is that a custom rom?
