U65GT V2.0 firmware for serial no below 1426
    Hi everyone,
    Are there any new firmwares available for units which have serial number below 1426? The serial number of my unit is: UG65GT16GB14219770395.
    and does anyone know if we should be expecting lollipop on talk 9x anytime soon?
    Thanks in advance for any help
    No V2.0 for below 1426
    There isn't V2.0 rom for tablets which have serial number below 1426. Your best shot would be latest Lepi's rom (v1.9W) or Brian's rom (900Supersport V1.8 Sep). They both are based on official V1.8 September rom.
    New features from V2.0 rom are:
    - White gestures
    - Black gestures
    - Chrome fix by stock
    - FOTA updates
    Both Lepi and Brian has fixed chrome issue on their roms (linked above). Lepi has also ported white gestures to his rom. So only thing that you are missing is black gestures and FOTA updates. You can't have double-tap screen on feature to V1.8 rom but you can have double-tap screen off feature with Nova Prime launcher and Screen Off and Lock app. Just add double-tap feature from Nova settings and then select Screen Off and Lock toggle for double-tap.
    Cube has not say anything about Lollipop. It is unlikely that Talk 9X will have Lollipop but let's hope for that. Maybe FOTA is our answer!
      Thank you for your reply, very informative! I just upgraded to Lepi's 1.9W version.
      Cheers
      [QUOTE=Vohukain;274879]There isn't V2.0 rom for tablets which have serial number below 1426. Your best shot would be latest Lepi's rom (v1.9W) or Brian's rom (900Supersport V1.8 Sep). They both are based on official V1.8 September rom.
      - White gestures
      - Black gestures
      - FOTA updates
