For the dual boot, would be good.
Example : Teclast X98 Air II Dual OS Intel Bay Trail-T Z3736F
Link : http://www.geekbuying.com/item/Tecla...GB-339220.html
explanation installe android by Teclass :
Windows 8.1 => Android
1. Burn Android bin file
Ensure adequate power
Download BIOS_X98_Air_3G_andriod extract to desktop tablet
(2) enter BIOS_X98_Air_3G_andriod folder
(3) Right-flash Run as administrator
(4) The following figure shows a success, hold the key to open ten seconds to force shutdown
2, burn Android system (landing Taipower official website> Software> Tablet firmware> Enter the ID number of the fuselage on the back of four to find the corresponding firmware package download extract, which has Andrews Brush tutorial)
Note:
1, X98 Air 3G Android Brush tool and X98 Air models such version is not the same, if the X98 Air Brush tool brush machine fails, Brush tool in accordance with the X98 Air 3G firmware package which provides Brush after reinstallation.
2, the original Andrews after 14 step tutorial plus or minus key press and hold the volume key to open will be 'Taipower technology' logo. win8 back to Andrews show is not the same, after the subtraction key press and hold the volume key, until the screen shown below appears, let go into a USB connector to the computer Brush
Link : http://bbs.teclast.com/thread-253763-1-1.html
I try to download the firmware for android Teclast X98 Air II, but it is not easy ( All is in Chinese )
