samsung galaxy s4 keeps resetting help
I have a Samsung galaxy s4 that keeps resetting does anyone have a solution for this problem? I have tried factory reset and recovery by holding the 3 buttons in and still no luck.... it is gt-i9505 in odin mode with android guy saying dowloading and stays there top left says write protection enabled, eMMC burst mode enabled I have turned off even though it says do not turn off target!! HELP PLZZZTags: None
Originally posted by billy2464 View PostI have a Samsung galaxy s4 that keeps resetting does anyone have a solution for this problem? I have tried factory reset and recovery by holding the 3 buttons in and still no luck.... it is gt-i9505 in odin mode with android guy saying dowloading and stays there top left says write protection enabled, eMMC burst mode enabled I have turned off even though it says do not turn off target!! HELP PLZZZ
install Samsung kies and see if you can reflash the firmware . as long as your not rooted you should be fine.freaktab art developerif you like my work please buy me a pepsi
There are currently 2417 users online. 1 members and 2416 guests.
