Should I return Tronsmart s89h
I should receive it in the mail this week and after reading all these issues with overheating I'm wondering if I paid for a heat rock? I would hate to waste money on a product that overheats with minimal use. So many good android boxes coming out. It's too bad because I am really excited for my first android box s89-h. I don't want to have to make mods to a brand new unit. Anyone have good experience with these boxes?Tags: None
Its the luck of the draw.
My first one developed the dreaded hdmi issue in three days and went back.
Took 5 months to get a new one which turned out to be a repaired unit with the wrong heatsink and the same hdmi issue.
I replaced the heatsink which is only held on by plastic clips just like motherboard chip-set heatsinks.
The hdmi issue required me to so a little re-soldering but now it just hums along.
You can check to see if the heat-sink came loose b popping the plastic feet of and unscrewing the three screws.
There is a antenna wire connected to the top from the board so don't yank.
Frankly though geekbuying has know about the issue for nearly a year and continues to sell defective boxes so you never know if you get a good one or a dud.
As a company i stay away from them there not all that honest.Mk802IV Neomode 1.9a original rom 720p
Ya I feel like I shouldn't have to take it apart. If I do I will be pissed off. I guess this is my test for geekbuying. If they fail I will never use them again. I do plan on watching movies and playing emulators. If I do have to take the lid off I will look to the forums for support. Thanks for the reply
Stress your system
StabilityTest (ROOT optional)
=> [CPU+GPU Stability Test]
and look what will happen...RK3288 Devices
- Overview BOX (LINK !)
I bought one at the beginning of the year.
It worked fine for a week, then it suddenly turned off while listening to music through my DLNA server.
Touching the case it seemed to be quiet warm.
Now there is no way to turn it on.
I'm quite disappointed, because I also bought a touch screen monitor, just to use it with such TVBOX, ad also an usb dvb-t tuner.
I hope geekbuying will send me a replacement as soon as possible... hoping that the new one will work longer.
There are currently 2164 users online. 0 members and 2164 guests.
