need a usb wifi driver
    i purchased a mk808 as a gift for my mother and she really likes it but the wifi reception isn't quite good enough. I went out and purchased a belkin n150 wifi adapter but can't find a working driver for it. if someone knows of one that works or could make me one....i'd REALLY appreciate it/be willing to pay.
    Their are some devs working on external wifi module code support.
    What you will need is support for your unit "usb wifi adapter chipset".
    This is advanced stuff so have a look at this thread over at
    Ask for help with your specific external usb wifi adapter. Good luck.
      Are you able to run an ethernet cable to the MK808? I was having inconsistent wifi performance with my MK808 so I gave up and ran an ethernet cable to it using a USB-to-LAN device and now it works great! I'm using the Finless 1.5A firmware.
      If you're interested, here's the USB-to-LAN device I used:
        http://www.monoprice.com/products/pr...seq=1&format=2
        sigh, ran out and purchased one (not the same one) and it doesn't work. Never powers on, i wish i knew how to build drivers.
