Cube 9x, SD card doesn't come out any more
    Cube 9x, SD card doesn't come out any more.
    If I press it in it doesn't release it.
    Is there any trick ?
    ***CAUTION***
    Hello, I have no experience with the Cube, but I had a similar problem on my Acer laptop.
    As such, I have a word of caution about forcing it out. I don't know if it was the card or the laptop that was at fault for the failure to let the card go. I did finagle it out, but it damaged the card's housing and rendered both the card and slot unuseable(slot can be used if I hold it in). If the data on the card is important to you, back it up before you attempt removal.
    I hope you find a less aggresive solution for your situation. Sorry I cannot help you.
    Good luck.
      So i hope i have never to remove it,so far it works
        There may be some trick. Hopefully someone will know in case you want to remove later.
          Video
          Here is video of Cube Talk 9X which is opened and you can directly see the sd-card slot. I don't know does this help you at all. I assume that you have already tried to push the sd-card's head (which you can see when sd-card is inserted) with needle from different directions.
            Thanks for the video, i used 3sd cards already.
            The first wouldn't come out everytime,sometimes it poped out later
            The 2nd worked fine
            Now the 3rd doesn't come out at all, no click on press
            All 3 are Samsung but different models
              The card came out by it's own yesterday. Now I connected some tape and plugged it in again
