questions about flash, firefox free space etc. on pipo x7
    hello . is there any chance to test one of those thing
    - is Firefox with extensions (eg. Adblock) works fine on Pipo x7
    - Does Adobe flash work on it (eg. website earthcam.com, or draculastream)
    - how much free disc space has pipo x7
    - can you turn on program portableapps from usb on pipo x7
    - is youtube can play 1080p
    thanks for the answer
    It has a full Windows desktop environment, so you can install whatever you want in that space -- including Firefox, Flash, etc. This is not Windows RT, and the only difference between this and Windows 8.1 standard is the browser search engine being required to be Bing. PortableApps run fine from the USB, it is a standard USB2 interface.
    As for free space, this was posted elsewhere (roughly 16gb + 5 GB Recovery Partition which you could reclaim):
    Kent A
    Certified Windows Enthusiast
      yes you can install any application on the SD card even if this program didn't support that (Like Onedrive and dropbox) by mapping a folder in the C: partition to that SD card or USB stick from Disk manager
