EM8N KoDi 14.0 New Firwmare (included 2 remote )
    1. Remote one: http://pan.baidu.com/s/1jGoq7NC
    2. Remote 2 (Normally remote ): http://pan.baidu.com/s/1qWynObM
    Firmware list;
    Hi, and thanks
    Any change of Kodi 14 auto frequentie switcher in this build? And Fast Ethernet?
    Greetings,
    shinysidewinder
      Is this firmware compatible with my box. Its M8 with round remote...with pcb board no. M9&M8_V0.92..just want to try and make sure its compatible..thanks
        Googleplay movies and flixster only playing audio no video picture and the installed kodi wont launch for me.
        spmc seems to be working ok and havent noticed no interlacing so far.
        Thank you hope you can provide a fix for above issues as working on older septemberish release.
          No replies ...any ideas...if the firmware from eny is compatible with M8..pcb. M9&M8_V0.92 board...anybody here???
          Does anybody even care to reply @Kelvin.Zhang.???where are u??anybody else.pls..???thanks..
            Any testers of this update..on old M8 pcb V 0.92..with round remote pls...anybody here??thanks
              downloading now will give u update when its installed
              QUOTE=warlock09;286913]Any testers of this update..on old M8 pcb V 0.92..with round remote pls...anybody here??thanks[/QUOTE]
                [/QUOTE]
                Thanks..will wait for your feedback.[emoji1] [emoji106]
                  looking good but found a more uptodate 1 which as smooth as anything
                  dl tjhe latest >>>>>>>>>21/02/15
                  Thanks..will wait for your feedback.[emoji1] [emoji106][/QUOTE]
                    Testing right now because i have nothing better to do than to test every free rom available for the m8,and so far,works perfect,flawless video,maxed out internet via ethernet. The remaining problem i have had with other roms is that after a while,video seems to zoomed or skewed to the right,and the only way to solve it is to disable an acceleration option of armcoded or something like that. When i do this,video playing seems to be jittery,not as smooth as with acceleration on. Hoping this roms solves that,and if it does,i will buy another m8 for a relative.
                      dont buy a m8 get a t8 v2 much much better m8
                        What's so much better,if i may ask
                          I just checked the price on the t8 and ,no thanks,they're too expensive. I'd rather try out the pipo x7 for that price.
                            [/QUOTE]
                            looks like they have a new version 12/03/15, anyone try it?
                              looks like they have a new version 12/03/15, anyone try it?[/QUOTE]
                              Just past by...anybody tried if its compatible???here??hello...[emoji108] [emoji108] [emoji106] ..i have M8N box with pcb no. M9&M8_V1.0.. anynone tried on their boxes pls..reply..thanks
