OTT-928 porting dualboot rom
port dual boot rom for my OTT-928 flashed ut3_dualboot rom & Android 4.4 & Ubuntu 14.04 Dual Bootafter traying a lat of IMG & ROMs from other devices , successful run dualboot on my OTT928 (cs928)working Linux Default login and password: ugoos & Android, wait for any sugestion , port work .Last edited by gumymoty; 01-26-2015, 17:04. -
You need 16 gig device to support the dual boot option and i think a few have made a sd booting card for it as well. I think its in the works for dual but limited to 16 gig devices right now.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
yes the last ROM is
Originally posted by scooter2014 View PostDoes anyone have a link to the latests firmware for this device?
good ROM:-) :-) :-) :-) :-) :-) :-) :-)
Originally posted by gumymoty View Post
How to flash packed firmware:
1. Download firmware and unzip it use 7z, winrar, winzip. Inside: Android Tool - tool for reflashing, DriverAssitant - tool to install drivers and firmware image file.
2. If it first time, you need to install drivers use DriverAssitant or manual when connecting device
3. After installing the drivers will run the Android Tool and click on the “Upgrade Firmware”. Click on “Firmware” and specify the path to the firmware file. You need waiting until the program downloading information about the firmware, then it will display some information on the screen.
. Next step, you need connect device to y, then follow these steps:
To connect the device to computer via USB cable, the device should use the OTG port.
Hold the hardware reset button. end power button realise wen dev is connected
Click the Upgrade button to the firmware of the device. At the end you will see a sign indicating a successful operation.Last edited by gumymoty; 01-31-2015, 10:16.
There are currently 1744 users online. 5 members and 1739 guests.
