Why X7 can't get maximum speed 2.16Ghz?
I have no idea about the temperature steps to throttle down the speed, maybe it is also "too" hot for 2.xGHz at the beginning or after a really short time...???RK3288 Devices
- Overview BOX (LINK !)
Originally posted by neomode View PostThe reason is that the Bios has a lock inside.
This prevents the CPU from running on that Speed.
Regards
Neomode
Originally posted by phinc View PostThat really sucks. I wonder why they chose the Z3736F instead of the Z3735F then. A Z3736F locked down to 1.6 ghz shoud be exactly the same as a Z3735F and the Z3735F is probably cheaper...
Rob
Originally posted by sogoku_vn View PostPipo X7 has Z3736f ~ 2.16Ghz but when I stress CPU 100%, windows show maximum speed is 1.6Ghz. Why X7 can't get maximum speed 2.16Ghz?
(*) Though heat and the X7 may not be great friends...
Originally posted by sogoku_vn View PostI used Prime95 to stress CPU
Originally posted by noggin View PostThink that is multithreaded - so you wouldn't expect it to hit the highest Burst clock rates as all cores will be running at max. Burst is there for single threaded stuff that run on a single core. If you stress all 4 cores at the same time you can't run at max Burst - as it would make the processor too hot. (Burst works by letting one core get hot because the others aren't AIUI)
Originally posted by sogoku_vn View Post... Now I understand. ThanksRK3288 Devices
There are currently 3165 users online. 0 members and 3165 guests.
