Hi.
Did you find a way to use sky go (italian version) on mk808?
I tried to use a version modified that could work in some android tablet different from samsung, but it doesn't work on mk808.
i tried to view by browser, for example dolphin, but after a few seconds working very well , i think that sky verified the operating system and showed a message error that is available only on windows or mac operating system. Is there anyway to confuse this control, so it believes that there isn't android ?
thanks
The Dolphon faq says: What is User Agent? How do I change mobile view to desktop view?
User Agent is the browsing mode you use when viewing webpages. Desktop view is a mode similar to your PC. Android view is also called mobile view, usually set by default. You can set User Agent of Dolphin Browser under Menu> More> Settings> User Agent> Android/ Desktop/ iPhone/ iPad/ Custom. Or you can download Desktop Toggles to quickly switch between mobile mode and desktop mode.
I have already set it to desktop, but the error message appeared. Do you mean that this is the metod to say "Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1)" or other ? If yes, unfortunately it doesn't work.
