Build 111K4 Finless 2.1
Kernel 3.10.33 Oman@ubunt
I put 3 files on the card to get finless 2.1. Seemed to install well
Questions
What media launcher do you use ? Launcher or Media Box Launcher? Keeps asking me to pick. Not sure which one to stick with.
Should you allow SuperSU accress to things like Kodi 14.0. I allowed it and i dont even know what its for ( Maybe I should have stuck with xbmc included with Finless 2.1?)
My HDTV seems to refresh the input when the box is connected to the tv? (probably tv issue im guessing)
I try and set my audio to go through receiver with Spdif Optical Cable but in sound options it stays on "Android Audio Track"
My box randomly is freezing during general use like the home screen for no reason. (after installing finless am I supposed to remove something off sd card? Maybe my box is trying to read something and freezing it?
Randomly it goes to the Swirling Amlogic A9 screen with the geekbuying logo below?
Sorry I just got this box and having a lot of issued already. If anyone could help me with some of it or even just pm me if they would like. Been looking over the forums for as much info as I could. If you can help me please reply. Thanks
