I am new to xbmc
I am new to xbmc
I cannot seem to find any answers to my questions online. I want to find the best set top box (using wifi) to obtain xbmc, mostly for viewing live TV/Cable Once I have the set top box, I want to know if I have to jailbreak it to add the add ons to get the live TV/Cable. Finally, I would like to know if I a going to have to add add ons from the PC or if I can add andnavigate everything from the set top box Thanks for the help.Tags: None
Im new to android boxes but.
I know the Minix boxes are supposed to have good wifi.
The new Minix Box looks very promising and I believe would work well for you.
As for jailbreaking. I'm still new but look into roms for a specific device. I know Finless roms work well. You may need to root(jailbreaking) your device depending on which one you pick.
Im not sure about add ons from the pc. I believe you can run everything from the box.
Hope I could help a little. I would just suggest researching devices on the forums.
Android, Windows, etc
Originally posted by drharrop View PostI cannot seem to find any answers to my questions online. I want to find the best set top box (using wifi) to obtain xbmc, mostly for viewing live TV/Cable Once I have the set top box, I want to know if I have to jailbreak it to add the add ons to get the live TV/Cable. Finally, I would like to know if I a going to have to add add ons from the PC or if I can add andnavigate everything from the set top box Thanks for the help.
There are currently 2175 users online. 0 members and 2175 guests.
