This is a work in progress, does the [BETA] tag. Your feedback is welcome and needed.
What doesn't work :
- Bluetooth doesn't work, it power's up but it's undiscovered
- Some streaming app's might not work. My ISP provides an APK to stream TV content, it doesn't work.
- And more ...
Some info on the build.
This image was tested, and prepared for an HD display. It uses a unified data partition, SDcard and Data share the same partition.
I have included CWM 6.0.51. Future updates, unless otherwise specified will not require a data wiping and will be done throw CWM or TWRP.
HOW TO INSTALL
- Download the CM build and unzip it.
- Place the FreakBox in bootloader mode. Flash the update image file, press upgrade button.
- First boot will be to Stock Recovery, it will format nand and after it will reboot by itself. Be patience and let it do it's job.
- Enjoy...
v0.1
www.freak-tab.de/abdul_pt/FreakBox/CM11_FreakBox_v0.1.tar.gz
v0.2
www.freak-tab.de/abdul_pt/FreakBox/CM11_FreakBox_v0.2.tar.gz
v0.3
www.freak-tab.de/abdul_pt/FreakBox/CM11_FreakBox_v0.3.tar.gz
