I'm renting a basement appt and my wifi signal is a little weak and fluctuates quite a bit causing lag and buffering at times. I did some research and found a bunch of wifi boosters, but they're boosters from the router end, which I have no control over.
Question is....can I hard wire a wireless device or card to the ethernet port of my Android box and use that for wireless over the built in card? If so, do you guys have any recommendations for a really powerful card that will give me a good connection to the router.
Thanks!
