Video of LeHome Assistant
Guest
Originally posted by gaetanolip View Postmay you post apk for server and client? you can extract from your device.
thanks
The client app (WiFi Display) is already included in HPH rom.
Do you need APK's because you're running non-HPH rom and/or device?
The technology itself is pretty much old stuff, so you can also use other apps for that.
But nontheless, it's very useful and attractive. Ofcourse, if you have quality hardware.
Originally posted by mo123It won't work on other devices, since there are changes embedded inside the firmware, kernel etc. to work properly.
You need to use a HPH TV Box with the latest firmware to use the app.
Now i am using firefly rom, waiting for your next rom , hopefully it will be possible to install on firefly..
Originally posted by mo123Latest Firefly ROM also works with remote app.
Android Only ROM here - https://drive.google.com/uc?id=0B7HO...xport=download
Dual OS - https://drive.google.com/uc?id=0B7HO...xport=download
There are currently 1959 users online. 0 members and 1959 guests.
