I find it odd because I can adb connect to other devices. I can even connect to my crappy Amazon Fire TV stick (and the stick sets a whole new level of crappy).
adb connect issue
adb connect issue
Why can't I adb connect to the R89? Do I need to load something on the box first, or change settings or change iptables? It's not urgent, I just wanted to see if busybox was installed (it is, I found out another way), and I noticed it wouldn't connect.
I find it odd because I can adb connect to other devices. I can even connect to my crappy Amazon Fire TV stick (and the stick sets a whole new level of crappy).Tags: None
Originally posted by RISCy Dude View PostCan Windows see it? If not, it could be a driver issue. Someone reported trouble when using the Windows generic driver.
I think they resolved it by installing the driver in the rockchip toolkit.
It's no big deal. I just wanted to know if there was a simple setting solution or something. Thanks for answering, though!
If I'm not wrong, at RockChip they don't use ADB over WiFi at default (they don't implement it)...
And as if that were not enough, at windows I have to use the ADB by neomode to connect to the box via OTG http://www.freak-tab.de/neomode/adb.zipRK3288 Devices
- Overview BOX (LINK !)
Originally posted by ropo View Posthttp://stackoverflow.com/questions/2...h-adb-over-tcp
setprop service.adb.tcp.port 5555
stop adbd
start adbd
Thanks! That's outdated, though. Here's the way to do it:
adb kill-server
adb start-server
adb connect <ip address>
It assumes port 5555 automatically. I can connect to the Roku, but not to the R89. As mentioned above, I don't think the R89 has the service installed/running.
Originally posted by ropo View PostSorry for the misunderstanding. My three commands need to be issued on the R89 to listen to port 5555.
I have a rooted ssh server running on the R89, so I use putty to connect and can type in the commands. Or you install a console app to type them in
There are currently 1876 users online. 1 members and 1875 guests.
