CWM on mk808?
I will do a CWM for you guys soon!
I have it running on mine already but it wont restore properly. It errors during the system restore. I believe its due to the ext4 / ext3 issues Bob has mentioned before. Also there has been once or twice I have booted into recovery and it after wiping cache, dalvik cache, fixing permissions, and then rebooting it still can corrupt the OS, and since the recovery part of the recovery does not work I was forced to rebuild my setup.TV Stick: MK808 // Tronsmart T428
ROM: Finless 1.7c w/Pimp My Rom // Nexus SDK2 Multi-Window v1.2
CPU: @1.6GHz OnDemand Governor NOOP I/O Scheduler
Recovery: ClockworkMod
Kernel: Omegamoon // 1080p OC kernel 720ddr 1.9cpu
Phone: Samsung Galaxy Note II
ROM: Whompasaurus v4.2
Kernel: Persus
I just have not had time to work on this with all the ROM's I have been doing.
However WARNING about all Rockchip 3066 CWM backups! DO NOT try to backup to external SDcard. There is a common bug in all 3066 devices with SDcard.
Read this:
http://www.freaktab.com/showthread.p...ard-Corruption!
So if you use my current CWM ONLY backup to internal SDcard. Then use a PC to copy to external SDcard. Then you can restore from external SD.
Look at there:
fun makes a funtional cwm recovery, stills some minor bugs but funcional, in mk808b works well with finless rom mk808b 1.5.
Date is not set correctly in backups images and can´t mount my ntfs external sdcard, but the rest works very well.
Only need a funtional 1080p kernel and mk808b rules
PD: Mount an external sd FAT32 works, and backup works too. But like finless say do it with caution, be aware of the problem that he said, posible corruption in the backup image, so best make backup on internal sd.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Done three backups on different roms with the cwm found at http://androtab.info/clockworkmod/rockchip/, all to external sd-card.
All three restores fine, swapped between them ~5-6 time.
As always, that do not mean that it will work flawless for you, so make sure to do a backup to internal if you really really want to be sure to be able to restore...
Re: CWM on mk808?
I tested external sd in mk808b too and no corruption by the moment.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
I do not have the B MK808 but I can confirm it appears the MK808 has resolved the sdcard corruption issues many RK3066 devices have. I think it is something with the hardware and not a ROM problem. I wish this would work on all my other RK3066 tablets!
Re: CWM on mk808?
Originally posted by Finless View PostI do not have the B MK808 but I can confirm it appears the MK808 has resolved the sdcard corruption issues many RK3066 devices have. I think it is something with the hardware and not a ROM problem. I wish this would work on all my other RK3066 tablets!
BobREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Re: CWM on mk808?
I just made a CWM Nandroid backup of my MK808, thanks to the information in this thread. Thanks to all for the knowledge!
I'm not the lowest of the low, but I am the slowest of the slow (49.6 mpg over 38k miles in Scion xB)MK808 w/Omegamoon kernel, CWM recovery, & Finless 1.7 ROM
There are currently 3004 users online. 0 members and 3004 guests.
