SPMC Kodi etc on MK808B Plus
Anyone else having issues with mpeg4 movies. It get a tick about every second. Of all the things to have trouble with....work arounds?Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****Tags: None
Originally posted by Johnoo View PostWow ... thats really bad.
Im trying to download the avi without any luck.
Think this is one for Oman.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
I haven't come up with any solution so far but you can easily check the symptom with XBMC (that's the only application I use) on any decent quality movie. You will notice the problem on any slow panning scene as the frame rate is not entirely smooth.
I really don't want to flash custom firmwares as I find the stock one pretty clean and suitable for the job but this is getting more and more annoying to be honest
There are currently 2002 users online. 1 members and 2001 guests.
