Wifi antenna replacement on mk808b
    Hi all!
    after many hours of readings I decide to replace the antennas of my original mk808b
    because I can't plug it to my router using a lan to Ethernet adapter and I don t want to add usb wifi adapter (due to cost and kernel compatibility)
    so I find a cheap 3bd antenna that I want so solder on my device in order to replace what I think to be the the origin of my weak and poor connection quality
    here s my question:
    do do I need to replace both antennas or only one is enough ?
    i searched on many forums but can't find an answer
    Thanks !
    Originally posted by ILoveBugMeNot View Post
    Hi all!
    here s my question:
    Thanks !
    Another option is a wireless bridge
